HP Photosmart C7280 Printer Logo
Posted on Nov 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i set up my printer to print wirless after setting up the wireless wizard with my router
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Nov 17, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557502
Points
31058
Presumably, the wizard helped you choose an SSID and a password.
On the controls on the HP printer, enter the SSID and the password,
and then the HP will try to connect to the wireless interface on the router.
Hw to set wirless password :/
Using your browser login into you router and go to the wireless section. There you can set or change the password. You can also use the set-up wizard to do this set-up.
Hello, I have a brother MFC-490CW mult-function printer (wireless) and I am having trouble setting up the wireless feature so my laptop can print to it via through my home network (Linksys wireless...
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
1helpful
Trying to install HP 2101nw wirelss print server but get message can't find the print server on the wirless network form this machine. I am trying to set this up stand alone , not via a router
The server maybe enabled but you need to navigate on the printer and select a wireless network you want to connect to (just like you would when you connect a computer to a wireless netowrk). Once the printer is connected to the wireless network. try it again
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
2answers
I cant connect wirelessy with my dell wireless 2350 broadband router
Unplug router for 10 seconds and reconnect. This will stop the static charge buildup that happens frequently with routers. If needed, set up a wireless network using the network wizard and set all settings to automatic.
1helpful
I wanted to set up the printserver wirelessly but everytime my computer searches for the printer server, it only registers in the wizard if i connect the WPS54G to the router. If i do this, i am able to...
The printer and print server has to be connected to the wireless router by a network cable for you to print wirelessly from the laptop.
If possible connect a long network cable between the print server and the wireless router or move the router next to the print server and printer.
You maybe able to use a wireless repeater/extender but is it worth the added costs and complication. The extended range would invite hackers unless you secure your system.
WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
Wirless Printer won"t network with the router
Check your wireless security settings and make sure the mac address of your printer is allowed to connect to the router. In addition, I would set my printer to only allow incoming connections from the router or you will have people driving by, printing ads that you probably will not like.
NetGear PS121 Print Server Problem
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
http://kbserver.netgear.com/kb_web_files/n101269.asp
http://kbserver.netgear.com/kb_web_files/n100033.asp
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
k24674
Grand Canyon Tech
Grand Canyon Tech
