Hi there its a common problem with maximum laptop. Reason is hi speed DVD. CD work but when you run DVD a bad noise is came from the Disk driver, is it? Try to clean the lens & slowly insert the DVD in laptop & then see what happens. If no changes then you need to replace the Disk Driver. Just Let you know I also have the same problem & i am not going to change it , because i know i will face same problem after few months. Thanks.
