I have a ip2600 that has had the waste ink absorber msg come up twice. After trying several recommended fixes involving pressing the Resume key twice then 4 times, etc., I've found the perfect solution. Start by cleaning the waste pads with tweezers, etc.
1. Press Power Off
2. Disconnect Power Cord
3. At SAME TIME, Press & HOLD Power Key while re-connecting Power cord
4. Release the Power button
5. Press the power button again
This will work!
try this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Let me know how it works.
I've tried this several times and it just doesn't work. is there any other sequence that would work? I am unable to visit a service centre as the only 3 and are in Surrey, Luton and Essex and I'm in Cheshire.
SOURCE: E27 Waste ink absorber full
canon mm140 E27 = Waste ink absorber full or platen waste ink absorber full what would be made to solve this problem
SOURCE: ink absorber is full
Use this tool
http://www.startcopy.ru/repair/files/ip1100.zip
!!! Don't forget to vote!!!!
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
SOURCE: ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
SOURCE: full ink absorber ip2600
try to reset the unit by pressing the Resume button and switch on the printer, release the Power button while still holding the resume button, then press the resume button twice and then release ... then press the Resume button four times... then press once the Power button... then switch off and on...
