SOURCE: hello, I have one samsung ln40a500t1f and the
good day i think theres a parts that links to the main board is shorted. causing not to on your tv. you need a qualified technician to fix that problem,
SOURCE: when i plug in tv red light comes on when i press
You may have main board problem that is not sending the signals to turn on the main power supply, but you need to look at the power supply PS_ON pin to see of it has 3.3~5vdc on that pin, if it does then the problem is in the power supply which you need to look for blown caps with domed tops.
See the boards here: http://www.shopjimmy.com/catalogsearch/result/index/?q=SAMSUNG+LN40A500&stock=all
Please read my guides before trying to DIY repair.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
