As a first step, power on the DVD player and open the DVD disc tray. In many of these situations, the tray must be open for unlocking to work. Once the tray is open, access the "Home" menu options on your DVD player by pressing the corresponding button on the remote. From here, press "Setup," and then choose the "Lock" menu option.
When prompted, you'll need to press the "0" key seven times, resulting in a display of "0000000." After pressing the "OK" button, you should receive a message on your DVD player stating "Region Free." This status update implies that your DVD player should now be capable of viewing DVDs tagged with various other region codes.
To test whether your equipment has been properly unlocked, place a DVD which is known to have a different region code inside the device. If your device has indeed been unlocked, you should be able to access the contents of the DVD with no difficulties at all.
the instructions provided here can be used for an LG DVD player region code unlock, you may find yourself needing a different set of instructions for unlocking other brands of DVD players. If you still cannot play the region-locked DVD, you can download a region free player software on your PC. You can try Leawo Blu-ray Player.
Hi, kindly get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__e45r6
