SOURCE: Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
SOURCE: Wiring diagrams for installing tweeters and crossovers in a door
try 12voltresource.com or google "wiring diagrams for car audio"
SOURCE: peavey eurosys 500 watt 4 ohm pa speaker fault.very low volume.
Indeed, sounds like a blown voice coil. Peavey Eurosys cabinets use Scorpion drivers, which have field-replaceable baskets. I assume the cabinet is a Eurosys 500XT? If so then you need a 15" replacement basket - part no. 15425 - about £75, but cheaper than replacing the entire speaker. Can purchase from http://www.neathmusic.com/products.aspx?stext=scorpion&action=search&mode=search&submit=GO.
SOURCE: i HAVE THE MTX TP112 SPEAKER, THE HORN TWEETER
It is a one piece horn need to replace the whole thing. These are not like normal PA speakers where the driver can be unscrewed from the horn lens and replaced.
SOURCE: Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
