I have encounter a problem regarding sending text message in my set nokia 5233 whenever i send message its goes to outbox and said for resend but message not send.
i have changed message number also but it not give result
Thanks
Hi first check that your Message Center number is correct..it should be led by +91 followed by country code +specific network center number.If the problem still persist restore the phone by selecting "Restore Only" or by typing *#7780#.And the last solution is call/contact your network provider.Thanks for visiting fixya
Remove your SIM card and try it on other hand-set or mobile and see whether it happen again or not? If it work on other hand-set or mobile then reset (restore factories) from your hand-set.
Thanks for using FixYa
Hard reset your phone. This will delet all the content of your phone so removed your memory card before resetting your phone. On the home screen type *#7370# .
check if the text message centre number is missing on the phone, in the message settings menu, if not done master reset it it will prompt you to enter codes The default codes for a Satio are as follows:
go to your message settings and check the message center number to see if it is correct.this can hinder your text messages from going.i hope this helps
there is a service center number in your message setting. if it is edited your messages wont go . correct service center can be taken from your service provider. if that is right the reset your phone once it will start working fine.
All you have to do is go to your message setting on your phone:
1. Open Messaging
2. On New message sellect options at bottom
3. Open settings
4. Open Text message, you should see: Message centre, message centre in use ect..
5. Open message centres this should go to next screen then open again, this screen should have : Message centre name & Message centre number (from your network provider you need to find out what is the message centres name & number are e.g in Australia it should be SMSC1 and number is +61411990001) then just manually enter these in there.
wen i text any msg it doesn go it says messga send failed and resend from outbox and when i go to outbox and send it from there it says the same thing i need helpp pleasee anyone?
