Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would also need to replace the tub? Is this correct? Would this still be under warranty?
    New Friend:
I just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Posted on Nov 30, 2010
6ya staff
SOURCE:
When the washer goes into spin cycle, it makes a very loud noise and then the spin cycle stops and F11 appears on the screen
This just happened to me tonight too - but I ddint get the F11 code.
When I stopped the machine, there were small plastic threads everywhere and when I investigated - the white plastic ring that is covered by the gasket - if you pull the gasket back you can see it - was shredded! I am afraid of the cost to fix this one. My machine is about 7 years old. Is it fixable - or should I give up?
Jun 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When the washer spins it makes a banging noise and the plastic around the tub shaves off
Thank you! We took our Duet 9150 apart and found that ALL THREE support arms were cracked. Same problem with shredded front tub also. My washer is a little over 7 years old. I called Whirlpool at the above number (you can't get "warranty service" but the parts service lady transferred me to the warranty dept). They were most helpful, and are shipping me both the metal tub AND the plastic which the metal destroyed, free of charge. Apparently your experience has shown them they have a problem with this...or I got a more helpful service agent!
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My front load washer has started making noise during its final spin cycle. It has been doing this for about 1 month now. The washer is about 2 years old and has been fine until now. What could my problem...
IF YOU REACH IN THE TUB AND SPIN THE BASKET BY HAND IT SHOULD BE SILENT. IF THERE IS NOISE THIS WOULD BE A TUB BEARING. EXPENSIVE TO REPAIR EVEN THO THE REAR TUB SHELL IS A PART ONLY WARRANTY FOR TEN YEARS MOST OF THE TIME. OVER PROBLEMS CAN BE A STRUT, OR THINGS IN THE PUMP. IF IT IS THE TUB BEARING YOU MAY NOT BE ABLE TO TALK TO SOME ONE IN THE SAME ROOM WHEN IT IS SPINNING. THIS PROBLEM NEEDS ATTENTION SOON. LET ME KNOW IF I CAN FUTHER ASSIST YOU.
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud knocking and vibration during spin
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer that is making very
It sounds like basket support failure. How old is the machine? They usually **** at around 5 to 6 years. Unless you are going to fix it yourself or it's under extended warranty, junk it.
The repair requires a complete teardown of the washer. two to six hours labor depending on tech skill level.
Jun 12, 2009 | Whirlpool GHW9200L Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
613 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
