Sir,
Manual removal of any spyware can be difficult. When you try to manually remove MalWarrior 2007, you risk destroying your PC. It’s highly recommended you use an automatic spyware scanner
to determine you’re infected with MalWarrior 2007. It’s also
recommended you backup your system any time before editing your
registry.
Your Windows registry is the core of your Windows operating system,
storing information about user settings, system preferences, and
software, including which applications automatically launch at start
up. Because of this, spyware, malware, and adware will often bury their
own files into your Windows registry so that they automatically launch
every time your start up your PC.
Because your registry is such a key piece of your Windows system,
you should always backup your registry before you make any changes to
it. Editing your registry can be intimidating if you’re not a computer
expert, and when you change or a delete a critical registry key or
registry value, there’s a chance you may need to reinstall your entire
Windows operating system. Make sure your backup your registry before editing it.
Computer acting funny after you’ve edited your registry and deleted
MalWarrior 2007 registry keys? Just restore your registry with your
backup.
How to remove MalWarrior 2007 DLL files:
Like most any software, spyware, adware, and malware may also use
DLL files. DLL is short for “dynamically linked library,” and
MalWarrior 2007 DLL files, like other DLLs, carryout predetermined
tasks. To manually delete MalWarrior 2007 DLL files, you’ll use
Regsver32, a Windows tool designed to help you remove DLL and other
files.
That’s it. If you want to restore MalWarrior 2007 DLL file you
removed, enter “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32
jl27script.dll”) into your command box, and press your “Enter” key.
Thanks
Good Luck
"Don't forget to rate the solution"
