Question about Behringer XENYX 2442FX Mixer
How do i hook up a powered moniter to the behringer xenyx 2442fx mixer?
    Genius:
  • 1,066 Answers
Hook it up to one of the aux output sends (1 or 2), and use the corresponding aux send knob per channel to put each channel necesarry into the monitor signal.
Posted on Nov 30, 2010
6ya staff
SOURCE:
How to connect a Behringer XENYX 2442FX Mixer to a laptop
you need a cable with two A3F  XLR s going to a 1/8" stereo phone plug, male. plug the XLRs into the Main out L&R on the mixer. plug the 1/8" into the LINE Input on the laptop. You should be able to get the cable from any music store,or Radio Shack. below is a link to the manual,in case you don't have one. Good Luck!
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
Aug 30, 2011 | Behringer XENYX 2442FX Mixer
My Behringer Xenyx 2442Fx does not get power.I have checked the power cable also.Kindly help me out
The switching power supply has probably failed. See if you can get a number off the power supply board like SPS400 or similar. Unless you are electronically adept this is lkely NOT a DIY repair.
Jul 26, 2011 | Behringer XENYX 2442FX Mixer
Pluggin headphones into my behringer 2442fx mixer is creating a lot of static coming out of the headphones.
This happens when you have lose earth connection from your main source power supply. Check the earth connections (grounding) which should be available in the mixer, i.e some power cords don;t have earth wire, so change this if you think yours don't have it. Also check the grounding of the other items attached to your mixer, basically grounding is very important to reduce the static shorts. Try changing the power supply source, change to other outlet and check if it is OK.
Apr 14, 2011 | Behringer XENYX 2442FX Mixer
Behringer xenyx 2442fx : I need to know the correct voltages out of power-supply. Mixer has been seen by a previous tech and now FX area and mixer level leds are off (I've been a user of this mixer...
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Feb 13, 2011 | Behringer XENYX 2442FX Mixer
How do you control volume for a specific instrement in a sub group being used as a moniter mix with out afecting the main mix
Send the signal to the subgroup via and Aux channel PREFADER. This will allow you discrete volume control over your monitor mix.
Jan 06, 2011 | Behringer XENYX 2442FX Mixer
I have a Tascam US1641 USB interface and wanted to know if you can connect a Behringer 2442fx to it to use it as a mixdown control for my music in Cubase studio5.
The 2442FX has a built in usb interface so there is really no need to use the Tascam. Here is a link for you:http://www.behringer.nl/EN/Products/2442FX.aspx
Oct 19, 2010 | Behringer XENYX 2442FX Mixer
Behringer XENYX 2442FX Mixer Logo
355 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Chickenwatt
Level 1 Expert
Ric Weide
Ric Weide
Level 1 Expert
Are you a Behringer Music Expert? Answer questions, earn points and help others
