Zenith ZEN700 Remote Control Logo
Posted on Nov 20, 2010
I have a Samsung remote and a vizio tv. I need the code to enter for the remote to work the tv.
ssekdad
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 14, 2011
ssekdad
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1448
Points
I have the 32" Vizio VP322 plasma HDTV and code 19 and 78 both work but only for power, volume and channel, doesn't work for input selection
Greenbrier International 110064 Universal 6 In 1 Remote code to program a Vizio tv
To program a Vizio TV with the Greenbrier International 110064 Universal 6 In 1 Remote, you can follow these steps:
  1. Turn on your Vizio TV.
  2. Press and hold the "Code" button on the remote until the LED light stays on.
  3. Use the number buttons on the remote to enter the code "11864" for Vizio TVs.
  4. Press the "Power" button on the remote to see if the TV turns off. If it does, press the "Enter" button to save the code. If it doesn't, repeat step 3 with a different code from the list below until you find one that works.
Other possible Vizio TV codes for the Greenbrier International 110064 Universal 6 In 1 Remote include:
  • 11758
  • 11756
  • 11742
  • 11740
  • 11738
  • 11687
  • 11670
  • 11587
  • 11365
  • 11136
Note: If you can't find a code that works for your Vizio TV, you can try the auto-search function on the remote. To do this, follow steps 1 and 2 above, then press the "Power" button repeatedly while pointing the remote at the TV until the TV turns off. Once it does, press the "Enter" button to save the code.
Remote control code for vizio vw26L
BEADSRULE, IT WORKED! I HAVE A VERY OLD ALLFORONE REMOTE AND THE LG 0178 CODE WORKED ON MY VIZIO TV THANK YOU! ;)
4helpful
2answers
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
2helpful
I just bought a Samsung HT-Z320 Home Theater System, but it does not have the cotroller codes for my Vizio TV. Any Help?
You should use the remote codes for LG. My Vizio Eco42 uses code 16 Press power, TV, hold power button down while pointing the rmote towards the TV, enter 2 digit code. If you hit the right code it will turn the TV off.
Hope this helps
Cheers
5helpful
2answers
Need vizio code for Samsung remote!!
Start with code 19. If it does not work try all the Daewoo codes..
146helpful
13answers
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
57helpful
13answers
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
234helpful
17answers
Code for Vizio tv
Go to the VIZIO site - they post codes. Try these for Cox:
0030 or 1758 or 0178
Dan
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
