You can Unlock the Mobile from the Security Lock or Password Lock using the Master Reset Code,You can get the Master Reset Code at http://www.superunlockcodes.com/unlocking-services/rs12wp6/ and Unlock it.I unlocked My Nokia and Alcatel Mobile from the Security Lock using the Master Reset Code...
SOURCE: i have a samsung solstice
no worries it happens alot infact it happened to me on my samsung as well lol! its a quick fix but it will delete all your info:( i found the info at tmobile.com/forums but its universal on ALL samsungs!
f your Samsung handset has a security code or phone lock on it follow these steps to disable the code. NOTE: This code is not used for Subsidy unlocks, Application Locks or PUK (PIN) code lock outs. Call Customer care for these. A phone lock or security code on most Samsung handsets can be overridden by performing a full reset on the device. This will set the security codes on the handset back to the default eight zero's (00000000). Important: This reset restores the original factory settings and will erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). Make sure you have backed up contacts, calendar appointments, and other data before continuing. 1. Power off the handset 2. Remove the battery 3. Remove the SIM card 4. Reinsert battery ONLY 5. Turn handset on 6. At the Insert SIM prompt screen enter the following code: *2767*2878# NOTE: If using a handset that was released after July 2009 use this code: *2767*3855# 7. The handset should display E2P custom reset 8. Power off handset 9. Reinsert SIM card 10. Power on handset 11. The phone should be unlocked NOTE: If you didn't get a E2P custom reset or a Full reset message on the handset your Samsung model may need an MCK code. You will have to call technical support for this code. Please have your IMEI number ready to expedite the process for this code. Your IMEI number is located on a label on the back of the phone,under the battery.
SOURCE: Needed Subsidy unlock code for samsung A887 Solstice...
the best answer is to contact the manufactuer
Method 1:
1 - Switch ON your Samsung SGH-A887 Solstice with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-A887 Solstice will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-A887 Solstice shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-A887 Solstice .
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A887 Solstice is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A887 Solstice .
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-A887 Solstice .
Each Samsung SGH-A887 Solstice mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A887 Solstice mobile phone using the form above.
