Vizio JV50P 50 in. Plasma TV Logo
Posted on Nov 20, 2010
When I turn on the TV with the remote first thing in the morning I get sound but no picture. I leave the TV on with the sound on for 30 minutes and than begin to turn it off and on till I get a picture but no sound which takes a few times to get.Once I have the picture I leave the TV on for 30 minutes and than I turn it off with the remote and I have sound with picture for the rest of the day .
bitdog
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Jan 27, 2011
bitdog
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
11730
Points
17
My 2007 Vizio JV50P HDTV10A I found at the garbage dump would turn on, make a pop sound, then nothing. So I replaced the bulged electrolytic caps on the power board with caps I scrounged off other discarded boards, and got the perfect picture in a couple hours. I used Panasonic caps? (curved T on top) FC type I believe? 1 - 10v 1000uf & 9 - 10v 3300uf & 1 - 16v 470uf & 1 - 50v 680uf, all 105c. The board had solder points all on one side opposite the cap can, so it was easy to do a pro solder job by flux & sticking the legs just barley out of the board surface.
I hope this helps somehow.
Bitdog
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
465
Points
OUR VISIO JV50P HDTV10A does the same thing every time we turn the tv on. Their is no picture, but their is sound (sometimes). Or we might get the picture, but no sound. And if we watch certain HD channels, the sounds doesn't come in good. What could the problem be with the tv?
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Nov 20, 2010
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
7049
Points
67
Does the screen look lit at all? you may have an issue with the sustainer boards (Y and Z). without taking voltage readings at the power supply board it will be hard to tell. if you check, there may be bulging capasitors on the power supply board. if so, that will need to be replaced. you can contact hdrepair for a diagnosis and repair.
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Poor picture AVR1600
This is not the malfunction to remote as you thinks. It with the set itself.
When turning on in morning can't get out of menu mode. Once it warms up for about 15 minutes it works fine, but starting to blink into menu mode more frequently. In the morning you can click menue on the...
Possibly could be the remote, the only way to find out is to pull the batteries out and leave them out for a while to see if it does it will the batts are out of the remote
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
1helpful
Westinghouse 42' tv working fine this morning, got home from work this evening turned tv on picture come on for about 4 seconds than blank screen still had sound pressed menu botton still blank screen...
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Frozen picture and no button response
Hi John.
Try unplugging the TV for about 30 minutes to an hour (reset TV) to see if this fixes your issue. If it does not, leave the TV unplugged all night and see if it will operate normally. Hope this helps.
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Black Screen with sound
make sure the TV time is correct. Reset the time. if that does not work, but the TV operates ok, it's in the circuit board, or could be a fuse problem.
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
