SOURCE: Behringer Eurorack Pro 12 input
Hi
you mean no power? if no power check the primary fuse! i can teach how to fix that, if you are a electronic technician?
Thanks!
SOURCE: no sound
http://www.behringer.com/EN/Support/U-Control-Downloads.aspx just got one, this link is all the available downloads for this. hope this helps
SOURCE: Behringer SL3242 Mixer has a noise problem.
It sounds like you have ground loops. This is noise generated by having interconnected equipment grounded at different physical locations. Especially a problem if you have a cable from your cable TV provider connected into your equipment.
Remove EVERY connection into and out of the mixer. Plug in headphones. Noise? If so, mixer needs repair. If not, re-connect equipment 1 piece at a time and assess for noise. If it slowly increases as you add connections you will need expert on-site help to fix it. If it is sudden, what was just connected is the source and steps need to be taken to lift the ground on the connection to that equipment.
SOURCE: hook up an eq to a mixer
yes any EQ can be put inline of any sound producing insterment....but why?
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
