Intel Gigabyte GA-8IDX 845 AGPset P4 Skt478 ATX Motherboard, Bulk Package (MBGA8IDX) Logo
Posted on Nov 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need update new BIOS for Intel 845 AGPSet BIOS for 8IDX F7 AWARD BIOS
Anonymous
Level 3:
  • Intel Master 32,281 Answers
  • Posted on Nov 21, 2010
Anonymous
Intel Master
Level 3:
Answers
32281
Questions
Helped
7905797
Points
102259
You can download the motherboarddrivers and BIOS updates from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : -http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
1helpful
I want to upgrade my CPU capacity from 1.2 GHZ and want to know my motherboard so much support??? my motherboard is GA-8IDX (845 chipset)
If you go to CPU-Upgrade.com, you can see all of the different processors that are compatible with your motherboard:
http://www.cpu-upgrade.com/mb-Gigabyte/GA-8IDX.html
The ones highlighted in pink are not supported for your motherboard, the ones highlighted in orange may or may not be, and all the ones in white are compatible with your motherboard. It looks like you have several high-end options, up to 2.8 GHz.
I want to install win xp in my laptop cq60-104tu but it shows always a BSOD. i m not able to disable the native sata from bios as it does not have that option in its system configuration. please help to...
hi there is a way of doing this but its a bit of a pain, you will have to create a customized windows xp disk which is quite involved, i had the same problem as i have a new laptop and it had vista on it but i preferred xp you have to get a program called nLite that you can create a image file of the original windows cd and then add your laptop specific drivers for the sata controller as i gather this is not a very old laptop such as mine, windows xp does not recognize sata drives as boot drives, you can download your drivers from gigabyte and insert them into the windows disk image, there is comprhensive instructions in nLite on how to do this, and it is quite simple even for someone with hardly any computer knowledge....hope this helps
PLEASE TELL ME HOW TO MAKE DISABLE SATA MODE IN HP DV 6703TX MODEL I WANT TO INSTALL WINDOW SERVER 2003
Well in the bios set up you`ll have SATA Emulation Options. You can set Emulate Sata As IDE
2answers
1helpful
Can some one quickluy givve me link to download sound drivers for gigabyte mother baord 845
Hello amanoj65,
I'm not sure that 845 is the right identification for that motherboard, but Gigabyte has a terrific site for downloading HERE. You will need to answer a few questions about the motherboard but I'm sure you'll find what your looking for.
Good Luck and don't forget to leave a rating.
Mark
Ethernet driver needed
Hi
From the following locations you can obtain the NIC driver for your motheroard.
http://america.giga-byte.com/FileList/Driver/desktop_driver_lan_intel_100_noap.exe
http://tinyurl.com/cvbayp
Try driver files from these locations and revert back if any help needed.
Warm Regards,
Zulfir Sadat M
Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
