Getting error code E014 in ir 3300 canon copier how to rectify
Hi
you have a fatal error
the motherboard of your printer in not working
you need to replace it and the cost is bigger than
getting a new printer
you better replace your printer
Pls vote us to keep us alive
How to solve error code E014, its the motor that operate the fuser film or its the gear that is connected on the motor that some part has gotten broken. Replace de motor or the gear
Not toner
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
