Usually, the problem is condensation on the electronic circuits. LG has a fan which moves hot air out. If you turn on the recorder, it will get hot and dry out the moisture over time. Then the DVD will read the disk and do recording too. You may also be able to play music cd to dry out the moisture.cheap way to fix it, is to turn it on but not use it for a while.
