Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Nov 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer displays an F11 error code. I replaced the MCU but still the F11 code. Wire harness is good.
  • Marvin
    Marvin Nov 30, 2010
    Have you tested the door latch solenoid for proper operation? Are you aware this is problem of epidemic porportians? it is called the Whirlpool kiss of deathe code, it should be recalled, contact Whirlpool on this.
Ginko
Level 3:
  • Whirlpool Master 19,396 Answers
  • Posted on Feb 22, 2011
Ginko
Whirlpool Master
Level 3:
Answers
19396
Questions
25
Helped
8077507
Points
55462
Hi.
It is probably the CCU (main control). Wiring harness, motor and drive train must be checked before replacing the CCU.
Here full troubleshooting for F11.
F11 is communication error between CCU (main control unit) and MCU (motor control unit - additional control module connected to motor and to CCU, located in a sealed box inside the washer).
This usually means that either CCU or MCU is defective. In some case the connectors or the wiring harness connecting the two modules is the problem.
The tech sheet says:
F11:Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Solution:
* Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
The wiring harness is tested using a multimeter to ensure that there is continuity between the MCU and CCU connectors. If a single wire is good it will read zero Ohms (closed) from contact to contact.
Motor is tested reading Ohms, it must be read about 6 Ohms on three different pairs of contacts.
Drive system in motor is checked observing if any of the parts are broken.
MCU and CCU are tested reading volts during operation and testing at component level. The testing must be done by a tech. Check CCU to see if there is any sign of failure (eg burnt spots).
Most of the time the problem is CCU. Trick to repair it include testing and eventually reheating the solder joint of the two on-board relays, cleaning connector contacts with circuit cleaner solution. This in case that the problem is CCU.
Disconnect the unit from power for five minutes as first test. This will reset CCU.
F11 error - Whirlpool Duet washer
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2P3BOEFKI
you'll need to call someone in on this one,boards are very expensive and like it says it names both the ccu and mcu boards or the motor,if you call say whirlpool they might give you the part but you pay for labor and they will have the boards on the truck,the guy will replace one board at a time to see what one is bad,not like the older machines that you can check the parts with a meter.good luck
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
F11 code on washer
F11 is:
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
Courtesy:JSrock
1helpful
F11 Code Showing
F11 is:
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
Courtesy:JSrock
2helpful
Whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
Control Unit (CCU)
* Check MCU
* Check CCU
* Check Motor
1helpful
What do the F11 and F02 mean?\
hiyas here is the meaning for the codes
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
F11 Means
Potential Causes
• Check MCU
• Check CCU
• Check Motor
I would suggest that you possibly call out an engineer
F11 Code Error
Hi. this is a Serial communication error
This will occur when the Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check MCU
• Check CCU
• Check Motor
Most cases, it will be a fualty wiring harness
5helpful
Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check MCU
  • Check CCU
  • Check Motor
6helpful
2answers
Washer has an F11 code what does that mean?
F11 means Serial communication error
Potential Causes
• Check MCU
• Check CCU
• Check Motor
(Refer manual to test the components)
Preferred to be done by a technician unless you are handy.Good luck with the machine.Hope I answered your question.
ERROR F11 (Whirlpool Duet GHW9300)
Hi there this is as it reads for your fault code F11
  • Check MCU
  • Check CCU
  • Check Motor
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
