Display has red tint across entire screen. Could it be the bulb? If so, is that still available? Approximate cost?
two possible solutions----either a problem on the small circuit board that is connected to the RED picture tube OR the red screen control is turned up too high. These sets have a small square block with RED,Green, Blue screen controls(same place also has red, green, blue Focus controls) if you remove the speaker grill you will find an inspection plate made of masionite---the focus/screen block is visable behind it----get a flashlight and look carefully at the block---one row of 3 plastic shafts is Focus(don't touch those) the other 3 are Screens(you should see R, G, B marked) go to a blank video input(one with nothing attached) and turn the RED SCREEN CONTROL JUST SLIGHTLY TO THE LEFT UNTIL the red goes away.
