Dell E193FP 19" Flat Panel LCD Monitor Logo
Posted on May 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all wrong. I've tried adjusting the colors with the buttons on the front of the monitor and also in control panel, but to no avail. Is there a driver or something I need to run the newer monitor on an older computer? Computer was bought in 2005 and has an integrated intel extreme graphics 2 video card installed. Thanks!
  • Bud Martin
    Bud Martin Nov 22, 2010
    All the pins at both ends of the vga cable are OK? No bent pins?http://www.fixya.com/support/r5093881-lc...http://www.fixya.com/support/r6150077-ba...
    Failed TV and Monitors:http://s807.photobucket.com/albums/yy352...
    Learn about bad caps:http://en.wikipedia.org/wiki/Capacitor_p...
  • wrappedinhis Nov 22, 2010
    Thank you for answering my post. The pins were not bent. We have returned the monitor, since I had tried everything I could find to fix the problem to no avail. Don't know why it wouldn't work, but it worked for them so they have it back now. Thanks again for trying to help. blessings!
Theo Nikolaidis
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 93 Answers
  • Posted on May 16, 2017
Theo Nikolaidis
Expert
Level 2:
New Friend:
Night Owl:
Answers
93
Questions
0
Helped
30930
Points
267
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
1 Related Answer
Ekse
  • 13435 Answers
  • Posted on Mar 11, 2008
SOURCE: vista video driver needed for Dell E193FP
There are no drivers for difrent monitors.
But if you provide your pcs brand, name, model.
I might be able to find a videocard driver witch might fix your problem.
Oh and what videomode are you trying to use?
1helpful
Need windows 7 drivers for Dell E193FP monitor, pls help
Look for Graphics drivers for your particular computer. Vista drivers should work fine.
Dell E193FP 19" LCD Monitor to work with vista
Go to Start, Control Panel, Personalize, Display Settings, Adapter, List All Modes, then select the mode you want.
Good luck
1helpful
Dell monitor enters power save
try to reconnect the cables to ensure it's properly plugged in (if you have another monitor, you can try it to ensure that your system is running properly) If you narrow it down to a monitor problem, it's most likely the inverter/power supply board in the monitor. If it's covered under warranty, you can send it back to Dell and they should send you a refurbed unit. If not, the board can be as expensive as finding a decent used monitor on ebay that works.
Just plugged a Dell E193FP monitor into my emcahine - running XP - turned it on and video display said ''cannot display this video type''
The computer is not able to communicate with the hardware properly. It can be solved installing the Video drivers (The video card drivers AND the display drivers).
Check for updates with the manufacturer of the video driver.
To determine what Video card your computer has, just right click in MY PC - MANAGE - DEVICE MANAGER and click Video, check properties.
Good luck.
Dell e193FPc monitor
The backlight or inverter may be bad. With the monitor on and the room dark, hold a flashlight very close and shine it on the screen . If you can see the normal display the monitor is OK but the backlight or the inverter which provides proper voltage to the backlight has gone bad.
Will the E193FP work with my computer?
I would suggest , check the monitor connections again. Dell flat panels are plug and play and donnot require additional drivers.
Make sure , you have not connected , both the analog (vga cable with a blue connector) and the digital (dvi cable with a white connector) to the back of your computer.
Refer to the the link below , to troubleshoot the monitor
http://support.dell.com/support/edocs/monitors/E193FP/En/trouble.htm
Thanks
Proton
Faulty monitor
Hi bakey 55 ,
Please click on the link below check whether you have connected the monitor in the same fashion or not......
http://support.dell.com/support/edocs/monitors/E193FP/En/attach.htm
You can also run a Monitor self test if the above set-up does not resolve the issue.(refer link below)
If the above 2 links does not help then call Dell technical support at 1-800-624-9896 TOLL FREE (USA)
Goodluck :-)
Vista video driver needed for Dell E193FP
1helpful
2answers
Dell e193fp
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
LCD Monitor went black
Yes this can be fixed there are a ton of sites out there that have replacement inverters or backlights. A site I found called digitaltechinc.com has parts that can be helpful for this problem. Only if you are willing to patiently do it yourself! It really is not that hard! Hope this helps!
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
