Press Menu button, then press the up arrow until you find the Adjust/Maintenance. Press the right arrow and search with the up arrow the Service choice. Then press the right button and search with the up or down arrow for Maintenance. Press the OK twice and the Install MK will disappear.
It meens that your printer has passed a certain timer count and needs a Mantenance Kit installed, in othe words "a good tune up" because it reached the recommended millage for it...
Its because you've gone past a certain number of pages printed.
Its asking you to install a new Media Kit
To reset the message -
1 Press the MENU key. 2 Press the or key repeatedly until Life Counters > appears. 3 Press the > key. 4 Press the or key repeatedly until >New Toner Installed. appears 5 Press the ENTER key. A question mark (?) appears. 6 Press the ENTER key. The toner counter is reset. The message display returns to Ready.
install MK means replace the maintains kit . maintains kit is belongs to drum ,developer , drive gears ..... after 250000 print it asking to replace all the things ....... this is not harmful the printer it will work fine don't worry about the install mk....
You have done more than 300,000 pages. I wouldnt waste your money on a Maint Kit, just stretch it out by doing the following.
Press Menu/Ok (Main menu) Go into [>>Service] Then press the right arrow. Then find [>> Maintenance] Press the ok key, then it will show [>> Maintenance?] Press the ok key twice, and it will reset all the counts on your consumable components (Drum, Developer, Transfer Roller, ETC)
Go to the menu on the printer and then scroll down to other in the menu then to service then down to maintenance and press enter. when you install the maintenace kit you have to activate developer in the service menu, then turn off the printer and then back on to run the developer unit up.
Print menumap from the printer and follow through to the service area on the display.
Any question ask me.
Machine maintenance(400,000 printed pages) Content of MK : Fuser assembly,Developer assembly,Drum assemby, various feed and other rollers,transfer assembly etc...
