Xerox CopyCentre C118 Copier Logo
Posted on Nov 22, 2010
Error code 008-111 and 008-131 out off paper but i have paper
Whit
Level 1:
  • Xerox Contributor 185 Answers
  • Posted on Nov 22, 2010
Whit
Xerox Contributor
Level 1:
Answers
185
Questions
Helped
107590
Points
97
The C118 errors you have are Registration Jam 008-111 and Fuser Jam 008-131.
You should order the Fuser Exit Sensor kit 015K60900 which is easy to install. Also, get the Registration Unit 059K45960
I hope this helps
Whit
Item, Inc. error code 008-111 and 008-131 out off paper but i - wrinaldo_2.jpg
2helpful
Canon printer error code 1256
Error Code: 1256 Cause: The paper output tray is closed or it has not opened.
Action: Confirm that there are no materials preventing the paper output tray from moving and that the paper cassette is inserted properly.
Open the paper output tray, then tap OK on the touch screen.
Important
  • Do not close the paper output tray while the machine is in operation.
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the
Paper-axis System.
Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared
-If this error code appeared but was NOT caused by a paper jam,
replace the Paper-Axis Motor Drive Assembly
I have a Cash Register Casio TK-3200 and I am getting error 15 and is not listed in the error listing.. how do I fix it ??????
Hi Luis - Error code 015 refers to Receipt Paper End.
Error code 014: Receipt paper end (1/2) RECEIPT PAPER EN (plain English message)
Error code 015: Receipt paper end (2/2) D
There are several versions of the TK-3200 manual but this one lists the error code you want:
http://www.salopcashregisters.co.uk/pdf's/TK-3200.PDF
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
