Noise aside, the most common cause of 202 codes on those things is the front door is not closed on the left hand side. It activates the laser shutter.
Mar 10, 2018
PrintCopy .infohttps://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ' Must include: cod
Fixyahttps://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Copytechnethttps://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
ressure roller fusing lamp temperature fluctuation The pressure roller temperature changes by ±20°C or more in one second. This occurs three times in one minute or two consecutive times.
Causes
• Loose connection of the pressure roller thermistor • Loose connection between the fusing unit and main frame
Remedy
1. Check if the fusing unit is properly set and connected to the main frame. 2. Check if the pressure roller thermistor connector is firmly connected. 3. Replace the fusing unit.
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
error SC533 is a problem in the fuser check/replace thermistors and check thermostat/fuse for broken circuits. then check the fuser if it is heating or hot then check the contact of the fuser and the machine there might be a loose contact on the fuser and connector of the machine. after checking it reset the machine by the way is this SC 533 for the aficio 2018 or other model?
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
