Haier 5 cu. ft. / 142 liter Chest Freezer HCM050WA Logo
Posted on Nov 22, 2010
The green light is flickering seems to be working ok.
Why does the light flicker when door is opened. The freezer seems to be working at this time.
It could be the button door switch that controls the light, or that a florescent lamp is being used in the cold fridge,
How to change the bulb on my freezer?
led's become weak over time. it is only an indicator that the power is on. Leave well alone!
Oct 01, 2014 • Freezers
Green light on chest freezer flickering?
this just means the light is burning out (loosing its filament) it does not effect the operation of the freezer, it just is an indicator that you have power at the unit.
Aug 30, 2014 • Freezers
1helpful
My chest freezer bush cf143gb works ok but the green light does not show it is
Good day James.
There must be a loose cable for the green light to come on. Your thermostat might need replacement especially if doesn't go on defost which happens automatically.
Light flickers when door is opened
it has connection problems when you open the door of freezer connecting wire turn gradually and one time comes up light normally,you repair connecting wire of lights.
The light on my chest freezer will flicker on and off when I open the door. It will only remain on when the door is in a certain position. How do I fix this? Secondly, the red "on" light on...
Both light flickering probably indicates a problem with the plug or the cord. If it was just the inside light I would suspect the door switch, but both light would indicates an open short in the wires or plug.
Check the plug connection at the wall and see if it is loose. While unplugged check the cord for any nicks or cuts. Plug something else into the same wall receptacle , like a light and see if the power to the receptacle is ok.
If none of the above work then it is time for a qualified repair person.
J
1helpful
The light that is supposed to indicate on/off is flickering. However the freezer still works fine. How can I fix this?
The flickering light is nothing to worry about... as long as it is flickering it is considered to be "on"
If there is no light then you need to worry...
The light flickering is not something that you need to fix...
heatman101
1helpful
Orange light in front is flickering almost constantly. What might this mean? The food seems frozen -ice cream is fine as are breads and meats.
It is normal for those lights ot flicker.. as long as the unit is working then do not worry about that...the light really is just showing you that you have power to the unit...
heatman101
3helpful
2answers
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
