If you have a 3 inch hose at 45 feet there is probably too much air pressure making the thermostat kick out because of the extra heat. If its possible to run a 4 inch pipe i feel it probably would work. Another thought. Are you using a plastic flex pipe. If so if you used an aluminum pipe you may have the additional air flow. A plastic flex is not a good pipe to use as it will bend and make less air flow hope I am reading this right.
SOURCE: Whirlpool Duet Dryer getting very hot, tripping breaker
what size is your breaker how many amps it should say on breaker are you cleaning the lint screen with it on top if the drier is getting too hot there is a device in it that's called a thermal limiter that would blow before the breaker would trip what kind or you in a house or apt. now on high heat can you hold your hand on the side of the drier.or cant touch it look at the vent under your house and tell me 1is it hanging down under the house then coming up to the hood 2whats its diameter3whats it made of we will go from there ok.there are three thermostats in that drier the first one runs at about 150 160 max second is a safety in case the first one fails it cycles at about 250 third is a safety if the drier exceeds 300 it will shut the heater down and wont rest it has to be replaced
SOURCE: Venting a dryer outside
What do you need to reverse?
I understand that the wall kit is to blow the heated air from the dryer to outside therefore not humidifying the laundry.
Are you trying to draw air into the dryer from outside or blow the air outside?
SOURCE: Dryer taking double the time to dry.....
I have had the same problem with my dryer for about 2 months. I bought a heater kit upgrade on eBay, http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220334963461 , and installed it myself this past weekend. Easy to install for a do-it-yourselfer. About 6 screws to remove, lay the dryer on the back and its all right in front of you. Dryer is working like it is new again.
SOURCE: Our dryer takes FOREVER to dry. Over an hour and a
Is the dryer vented properly to the outside? Feel the amount of air flow when it's running and empty. It should be substantial. If it feels weak, you need to take the back off the machine. There is a metal 'box' that is connected to your vent line going out. Take the cover off the 'box and it is probably full of lint. This blocks the exit air and causes your problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Electric dryer will not dry
Is the dryer heating up? If so, then you have a problem with the moist air being taken away, which would indicate a problem with your fan or the vent. If it is not heating, then the problem is with the element, either bad or not getting power. I like to get parts from:
Belks used appliances 704-864-4496. May have a used part to save you money, or he can order and ship new parts if he does not have in stock. Either way, Harry Belk (the proprietor) usually saves me $$$.
