Firmware error:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
SOURCE: Brand new HP Laserjet printer
hi the chairman..
when do bought that printer..from my experiance the paper curl couse of fuser got problem...
need to bring to hp centre...
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
SOURCE: cp 2025 cartridge tray is jammed into printer.
If the tray is visibly damaged there is not much to do and service is required, you can try to remove the carriage but this would void your standard warranty, your best bet here is taking the printer to an authorized support provider near you, you can find the closest one to you on the hp website or call hp's tech support.
1800-334-5144
Al
[email protected]
SOURCE: hp printer cp 2025 erorr code 58.04
This error code indicates "Low voltage power supply error"
SOURCE: problem in hp cp 2025 color laser printer that
This error typically indicates that the cartridge was moved (e.g. previously installed) from another printer to your printer. The error should not affect your ability to print. If you want to clear the error, replace the affected cartridge with a genuine HP replacement.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
