Hope you are fine, ch are in two forms steady one and the blinking ch.
Steady CH
This is associated with door switch for either front cover or side cover. Check that the front cover of the copier and the right side is well closed.
Blinking CH
This is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp Ar016ft and you are done. Good luck.
SOURCE: My sharp photocopier is AR.5316E,and recently is showing "Ch"
Ch means the side door is not closed or the toner is not installed correctly.
SOURCE: My sharp ar-5316e error code
L4 -01 main motor lock , check harness disconnection between the MCU PWB and the main motor.
SOURCE: i have sharp AR-5316e and
CH
ON
None Content Side door open
Detail The side door is open.
Cause Side door sensor abnormality
MCU PWB abnormality
Check
and
remedy
Check that all the side doors are closed.
Replace the MCU PWB.
CH
Blink
None Content Developing cartridge not installed
Detail The developing cartridge is not installed.
Communication with the CRUM cannot be
made in initial check of the CRUM.
Cause Developing unit disconnection
MCU PWB abnormality
CRUM chip abnormality
Check
and
remedy
Check installation of the developing unit.
Replace the MCU
