SOURCE: Kodak EasyShare z812is Battery issue
Try using the Kodak CRV3 lithium battery, I will cost you, but the battery works. The z812is is to powerful for any rechargeable battery.
SOURCE: kodak easyshare p880 camera
I shake mine and it sometimes comes on. It's like something is sticky inside it and a brisk shake loosens it. Good luck.
SOURCE: Hi, My Kodak EasyShare C613 intermittently
My camera is stuck on the screen that says "lens error" and then has four different numbers in a row. The camera lens is fully extended and will not shut off...any suggestions of what the problem could be?
SOURCE: Kodak EasyShare P880 not getting
Hi stanleychen1,
Did you upgrade the firmware to v.1.02? This should solve this problem. The upgrade can be obtained at the Kodak support site.
Hope this helps.
Gr. Blackbear
SOURCE: My Kodak easyshare p880 will
Go to www.dpreview.com and Kodak Talk. Search the forum for "P880 Power Switch problem".
Problem can be solved with the use of WD40. Read the solution on Kodak Talk first!!!
Hope you'll succeed!
Gr. Mart
Gr. Mart
Gr. Mart
