Question about Samsung TXJ2754 27" TV
How do I get closed captioning on a Samsung TV model TXJ2754?
    Top Expert:
  • Samsung Master
  • 76,177 Answers
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Posted on Nov 23, 2010
  • elgeen Nov 23, 2010
    I was able to find the closed captioning Set-up etc. with no problem but no closed captionioned writing appeared on the TV screen even though I tried 12 different channels and even one VHS tape.
6ya staff
SOURCE:
How do I get closed captioning on my samsung 6300 TV
A Google search suggested this:
To turn on and set the Closed Caption function options, follow these steps:
  • Turn on your TV and STB.
  • Press the Menu button on your remote control. ...
  • Highlight Setup, and then press the OK button on your remote control. ...
  • Highlight Preferences, and then press the OK button. ...
  • Highlight Caption,and then press the OK button.
Jan 14, 2018 | Samsung Televison & Video
How do I turn off the subtitle / closed captioning on a Samsung series 6 6300?
Is the captioning coming from a source such as a Sky box? If so, you need to switch off closed captions on the source box and not the TV.
Sep 07, 2014 | Samsung UE40B7020 40 in. LED TV
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do I make the closed caption bigger. It has a black background and white letters that are too small. How do I fix it?
I suspect it depends on the TV. On my Viewsonic TV, I can select my CC font by choosing Menu > Option > Closed Caption. When the CC is set to On, go to Option and select Font Size.
On a Samsung TV, I use Menu > Setup > Caption. With the Caption set to on, then choose Digital Caption Option and Size.
Note if the captions are being provided by a set-top box, you may need to set the caption size on the box directly.
Please add a comment with your TV manufacturer and model; I'll try to find the specific directions for your TV.
I hope this helps.
Aug 12, 2011 | Televison & Video
The V-chip is lock on my samsung tv and I don't know the code
Look up your model number of your television on the internet. Look up how to reset the v-chip.
Dec 12, 2009 | Samsung TXJ2754 27" TV
How do I turn ON Closed Captioning.
It sounds like that option is not available on that model , contact samsung
Dec 07, 2008 | Samsung DLP HL-P5663W 56" TV
Closed caption
You have to activate the closed caption option on your charter cable box. Power off your cable box and immediately push the menu button. A menu should appear where you can toggle captioning on/off. Good luck!
Oct 27, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Samsung TXJ2754 27" TV Logo
1,183 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
