hello Danj29,
I suggest you make sure that your Vista is configured to connect to a private network. To do this follow these steps:
1. Click
Start, right-click
Network, click
Properties. -The
Network Sharing Center window displays the network type in parenthesis after the network name.
2. To the right of the network name and type click
Customize.
3. In the
Set Network Location dialog box, click
Private, and then click
Next.
4. In the
Successfully set network settings dialog box, click
Close
By changing your network location type to private, network discovery is automatically enabled in the
Sharing and Discovery section of the
Network and Sharing Center window. The following additional file and printer sharing options must be manually enabled:
- File sharing
- Public folder sharing
- Printer sharing
- Password protected sharing
When all of these sharing and discovery options are enabled, your computer can:
- Locate other computers and devices on your home network and have other computers locate your computer
- Share its folders
- Share its Public folder
- Share its printers
- Require user names and passwords for other computers that connect to the shared folders and printers of this computer
To enable file sharing, do the following:
- In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to File sharing.
- Within the File sharing settings, click Turn on file sharing, and then click Apply.
To enable public folder sharing, do the following:
- In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Public folder sharing.
- Within the Public folder sharing settings, click one of the following:
- If
you want to share the public folder so that other computers on the
network can access the Public share to open files, but not create or
change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
- If
network can access the Public share to open files and also create or
change files, click Turn on sharing so anyone with network access can open, change, and create files.
- Click Apply.
To enable printer sharing and share all of your connected printers, do the following:
- In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Printer sharing.
- Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
[Optional] To enable password protected sharing, do the following:
- In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Password protected sharing.
- Within the Password protected sharing settings, click Turn on password protected sharing, and then click Apply.
Hope you find this helpful info and thanks for using the FixYa service
Kind regards
