Hope you have received helpful info about unit problem from our expert, please accept the solution to close question thread.
Thanks.
Make sure the platen (roller) is pushed down all the way. It must lock.
Also, see if the ribbon is feeding properly, characters should be evenly spaced on the ribbon. Other possible causes ..solenoid pad or selection plate, neither of which you can do yourself.
Everything you have suggested, except the solenoid pad and selection plate have been tried and are working properly. I guess it's now off to the repair shop 40 miles away!! Thanks for your help. DEN
