Sentry Fire Safe -  Safe - DS3607 Logo
Posted on Nov 24, 2010
How can i stop my sentry safe from beeping when i push numbers?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2913
Points
I have a 1459E model sentry safe. I was having the same problem. I removed the front electronic assembly, easily removed the circuit board, located the annoying beep speaker, then fliped the board over and heated up the two solder pins holding the speaker to the board, then it easily pulled away from the board. Speaker removed, I then op tested it by plugging it back the way I took it out......and voila! NO BEEPING!!! YES!!!
How do I turn off the sound on my sentry safe lock box?
The sound does two things
It lets you know you have done a positive button push.
It beeps when the battery is low to alert you to change them and save you having to cut the back off the safe.
It isn't programmable, snip the wire to the sounder, but it is likely hard soldered to the main board.
2answers
I have a sandleford safe es23 if i punch the code in the safe beeps until i open it with the keys and disconnect the batteries. What am I doing wrong
we are looking after a friends place with one of these safe's in them, my daughter has pushed buttons and it wont stop beeping, we dont know the code or anything?? how do i stop it beeping??
We have a Sentry safe model number SC 3877. We just changed the batteries. We are imutting the correct code, the light turns green but does not give the 1 beep and we cannot open the safe. If we put in...
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
2helpful
How do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking the Fireproof Sentry Safe open.
4helpful
I have the combo, but what is the direction? Do
Locksmith Instruction manual on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Pull the handle down; cracking Sentry Fireproof Safe open.
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
I got a new Sentry safe. I cant find my instructions but i got my numbers to get in. how do i enter my numbers. its a twist knob.
Safe and vault techs advise
Pull the handle down; cracking sentry safe open.
1helpful
NEED TO OPEN A SENTRY SAFE BUT DON'T KNOW WHICH WAY TO TURN AND HOW MANY REVOLUTIONS PAST NUMBERS SHOULD BE USED. i HAVE A OLDER SENTRY VALUE GUARD SAFE, MODEL # 1330
Locksmiths advise If your safe doesn't have a key, skip Step 3.
Sentry safe ob0100 wont open with 3 digit com
A1 locksmith say's If your safe doesn't have a key, skip Step 3.
2helpful
Need assistance opening my Sentry 1250 safe. I have combination but do I start at 0 and pass the first number then stop 2nd time around at first number then go straight to the other 2 numbers?
Locksmith instructions for sentry safes
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
