F11= Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. The board needs to be replaced. Here is a link to it.
http://www.repairclinic.com/PartDetail/Circuit-Board-or-Timer/1059575
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
Sorry to be the bearer of bad news.
F11 indicates a fault with the main control board.
