ASUS A8V-VM Motherboard Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be detected in ur system. So i need patch or any other software to solve my problem.
Sreekanth C Menon
Level 2:
  • Expert 140 Answers
  • Posted on Nov 25, 2010
Sreekanth C Menon
Expert
Level 2:
Answers
140
Questions
0
Helped
31031
Points
387
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
1helpful
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
I want to update my Asus A8V-VM Bios...model: A8V-VM
You can find all the drivers, bios, information for the Asus A8V-VM HERE.
The link to download the BIOS and BIOS-utility HERE, after selecting the used OS.
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
I have a8v-vm motherboard...my ad dvd writer was not working.so i purchased new sata dvd rom but now problm is thai i cant boot from it or instal xp buy this......what i do now..what is the setting in...
Restart your computer.
Press <DEL> to enter BIOS SETUP.
Look for "Boot" options, and change the "Boot Order" to make the CD/DVD the _first_ boot-device.
Save/Exit from BIOS SETUP.
Boot from the CD/DVD drive.
I have a A8V-VM Ultra socket 939 with AMIBIOS 0903 version. When I boot normally with the Windows XP (SP3) on the hard disk it seems to work fine, nothing abnormal happens. Booting with a Ubuntu 10.04...
Go into your bios settings make sure your hard drive is set to IDE and make sure secure boot isnt on. You could just try resetting to default.
Also check your ram. Take out one then the other. This usually happens when Windows loads the files it is about to install into the ram. It takes up a lot of space and could cause faulty ram to overload.
3helpful
3answers
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
http://support.asus.com/download/download_item.aspx?product=1&model=A8V-VM
Dont forget to rate the advice.
http://www.aa1consulting.com
PCI IDE slot does not detect hard drive
Check if power cable to the HDD is connected properly or not.If it is connected then check the jumper settings on HDD.
Thanks
Hard drive not found
When is your hard drive not recognized?
At boot or in the BIOS?
You might haven connected your hard drive correctly or you'll need to enter bios and select an option for bios to detect your hard drives and save the new configuration.... otherwise there is a serious problem with your hard drive not functioning.
At windows XP?
You might need to enter windows ADMINISTRATIVE TOOLS in the CONTROL PANEL and click in COMPUTER MANAGEMENT in there click STORAGE/DISK MANAGEMENT you'll see all your connected hard drives, your new hard drive should be listed there, but may not have a letter assigned/partitioned or formatted. Do so and it will be recognized.
If you're trying to install windows XP?
It's probably because your PC has the new SATA interface hard drives, you need to load a special SATA driver through floppy disk during at the beginning of windows XP setup, for it to find hard drives on your pc. You need to make this floppy disk with files that are available on your motherboard CD, in there are all the instructions you need.
5helpful
6answers
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
