Rival 18 Qt Roaster Oven with Buffet Server Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do I put water on the bottom of my hamilton beach roaster?
Anonymous
Level 3:
President:
  • Master 1,654 Answers
  • Posted on Nov 25, 2010
Anonymous
Master
Level 3:
President:
Answers
1654
Questions
0
Helped
597688
Points
5047
Are you trying to keep things warm, like with a warmer tray? then it will be fine if you add water, and this can also keep the food a little moister from the steam. it is not neccesary to add water but you can. Water will leave a deposit line inside the unit when it heats up and starts evaporating, this won't hurt anything and you can clean it with some cleaner and a scrubber. If your a cooking with it, then you don't want to use water, just put the food in the insert and cook it like that.
1 Related Answer
Anonymous
  • Posted on Aug 04, 2010
SOURCE: missing insert pan for Hamilton Beach Roaster oven model 527
lost electrical cord for the hamilton beach model 527, Where can I get a replacement?
thanks
Jan
Do I I put water between the insert & roasting pan in my Hamilton electric roaster ??
Hello, Judy -
Do you mean a Hamilton Beach electric roaster? If so, it will help in providing an answer to know the model number of your roaster. You can choose Comment and type the model number in the Comment box.
See the general information here regarding roaster ovens:
https://www.ehow.com/info_12328329_put-water-bottom-roaster-oven-before-cook.html
Best wishes.
Can I cook a stuffed turkey in my Hamilton Beach Roaster Oven, and how long per pound do I cook it?
The roaster oven will do just fine... just make sure to have enough liquids in there...
You cannot really go by the pound, but a 10 pounder will take about 4 hours a 15 about 6 and a 20 about 8, at 350... so that should give you a good idea...
heatman101
2helpful
My 22 lb turkey isn't going to work in my Hamilton Beach roaster using the insert pan. I probably can't take it out and just cook in the bottom part, huh?
I never tried it with mine, bit the lower part is waterproof and the same material as the pan, so I would say you probably could, however, since they heat from the sides try to make sure the turkey isn't touching the sides directly or it may burn.
The dial (temperature control knob) came off my Hamilton Beach roaster over and is lost. I need a new on-- the oven works great! Thank you
Look on the bottom of your roaster for the model #:
Example: #32182
Call customer support - 1-800-851-8900
or email them
http://www.hamiltonbeach.com/contact-us/contact-form.php
2answers
Missing insert pan for Hamilton Beach Roaster oven model 527
I am currently selling a triple buffet server by GE. It is new and in the box and says 'fits most 17 and 18 qt ovens. I bought it to use when I borrowed a roaster oven, but ended up never using it. It has 3 compartments, enamel on steel. It would take at least $11.00 to send and I would like $15.00 for the insert. If interested, answer this.
I just bought a used Hamilton Beach electric roaster. It did not come with a manual. Where can I find one?
Thank you I found what I needed on OwnerIQ. I was able to print off the manual from that site.
Wendy
Top Rival Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
