Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
wcdoc1953
Level 2:
  • Expert 280 Answers
  • Posted on Nov 25, 2010
wcdoc1953
Expert
Level 2:
Answers
280
Questions
0
Helped
129707
Points
552
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Pride Jazzy Jet 3 Ultra Electric Wheelchair. Fuse keeps blowing I was given a Jet 3 Ultra for my mom .. I bought new batteries and installed them.. charged them over night ..
Question edited for clarity.
You have a dead short somewhere. You need some electrical knowledge and a digital multimeter for testing. Take all the covers off. Look for wiring that has rubbed through and touching or melted. Disconnect one of the motors and replace the fuse. If it still blows, reconnect that one and disconnect the other motor. If one motor doesn't blow and the other does, you know you have a faulty motor. If neither stop the issue, then you move up to the controller and look up there. With a meter you can check for shorts within the motors, as well as grounds.
Or just take it to a Service Centre and have it repaired and serviced properly.
Basic troubleshooting
INFINFB2045 Jet 3 Ultra Troubleshooting
Pride Mobility https://www.pridemobility.com > pdf > infinfb2... PDF troubleshooting instructions for the Jet 3 Ultra Power Chair. This information is to be ... A blown charger fuse can cause the charger inhibit to activate.
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Changing battery or is it batteries
lots of questions how old is chair, how old is batteries, it has 2 by the way 12v connected in series giving 24v , always change both not just one, check for loose connections first and be sure charger is good try on another chair and/or try another charger on yours if possible they are 95% interchangeable
1helpful
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
I have my Pride Jet 3 Ultra Power Chair (D504002.04) since 3i/01/09 the battery condition metre is 2 lines red.I plug to recharge the battery but it is not charging. lPlease, may you tell me the...
Isabel you could have battery problems or it could be a charger problem. you would need to contact your provider (where you got the chair and ask them to check it for you) Now Plug the charger in for a couple of hours and look at the light on the charger (it is located under the rear of the chair) if it is green then it indicates a full charge if you have no light then it could be that the batteries are getting the charge or the chharger is not operating A tech will haveto determine the problem for you. Sorry I couldn't give you a instant fix Hope this helps
2answers
I need a charger for pride ultra jet 3
I can supply a charger you can reach me at 770-719-9998 or toll free at (866) 598-6230
just ask for Dallas
1helpful
Batteries run low fast on jazzy jet 3, heard brakes might be failing or motor needs replaced after replacing batteries?
one battery was low,,,,not sure if anyting else is bad, used chair...by having only one battery low, it ran down the chair...
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
