Lg 42pc1dv have just purchased a lg bluray player and hdmi cable selected corret socket get the picture ok but no sound, all works fine on daughters tv.
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
you will know if hook to another set but I in our shop have seen similar issues where either a cable or sat box had to be rebooted or even a software upgrade done to the set.
HDMI has mostly sound issues--my experience is it also does NOT like to be connected to units which are on at the time.......
unplug TV and Bluray power cords from wall socket, replug HDMI cable in both units, replug power cords back in, turn them On and check.
Let me know how it worked. it seems Bluray player set its display resolution bit higher that TV doesn't support.
Please connect Bluray in TV by usual AV cable (yellow-red-white) and go to BD player setup menu and reduce HDMI Out resolution like 1080p to 1080i, then check it in TV HDMI input.
You do not tune in your Bluray player but connect using an HDMI cable or Composite cable. If you have a HDMI cable connect the Bluray's HDMI out to the TV's HDMI in at the back and using the TV's remote switch the Input source to HDMI. You will see the image from the Bluray player in high definition. If you don not have a HDMI cable connect the composite out of the Bluray player using the Yellow/Red/White cable to the TV's composite input ( same three color sockets ) and switch to AV input on the TV. Using this connection won't give you high definition image but will work OK.
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
