SOURCE: Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
SOURCE: Panasonic VDR-D300 Camcorder cannot play DVD-RW (VR format) on PC
your usb cable has malfunctioned
SOURCE: A grinding sound coming from inside the camera (PanasonicHVX200A)
If noise occured during while OIS function is on,then must lubricate the axis inside lens underneath the ccd block.Due to friction of the movement of the coil used for moving lens for optical stabilizing function makes noise,but if this is not the problem, camera board must be next suspect,so first clean and lubricate and after ask service for cost.So generally speaking ,the problem is on the lens unit ,or the camera board which drives it...
SOURCE: Cannot re use a formated SDHC card in Panasonic HDD camera.
after formating the card u can re use it ,somthing is wrong with the card.Try once again after cleanning the card and card reader.
