HP LaserJet P3005n Printer Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP 3005dn Printer Tray 1 paper jam error - HP LaserJet P3005n Printer
Sudeep Chatterjee
Level 3:
  • HP Master 3,267 Answers
  • Posted on Nov 26, 2010
Sudeep Chatterjee
HP Master
Level 3:
Answers
3267
Questions
10
Helped
1159138
Points
10260
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
2answers
ERROR CODE E4 ?
Go to utube https://www.youtube.com
and type in your brand of printer / copier and ask after that how to fix error code E4 .
Example : how to fix error code E4 on a HP model 2400
2answers
Keep getting paper jam error with my hp 1610 al in one printer there is no paper jammed in the printer
If your printer has a paper tray, do not fill the tray. Overfilling the paper tray is frequently causes paper jams. Many printers have sliding mechanisms that allow different types and sizes of paper to be fed into the printer. If the slider is not correctly positioned, it can cause a paper jam.
Getting error jam in tray 1 in hp printer
Check tray 1 pick up roller, paper sensor, clean registration sensors..check any paper particles jammed inside..
26helpful
3answers
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
3helpful
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
1helpful
Fussion Error
This has been very common lately. Sounds like the fuser is starting to fail. If the printer is under warranty you may want to claim this.
2answers
HP 4200 printer paper jam. No paper is jammed
OK, if the printer says jam but no paper inside and prints after you open and close the cover the paper likely never made it out of the tray. Or the machine thinks the page never made it out of the machine.
As far as input check your rollers 1 in the tray and the pick up roller in the machine if you don't have alot of pages on the machine these likely OK.
Next (and this I have found often) check the paper back stop in the tray. This is the guide to set the length of paper. If it is set just a little long the roller cannot catch the edge of the paper. Sometimes the teeth the guide sets in are broken or worn.
The output would be the sensor in the fuser replace fuser.
Hope this helps
HP 3419A
Hi Mose,
I never faced this problem any time , but could find a solution for you which i think will be helpful.
The paper jam error state occurs if the printer detects a paper at the platen after attempting to eject paper to the out tray. Clear the paper path.
<Power and Resume>
1. Turn the printer OFF and back ON to allow the printer to clear the jam.
(If the paper remains jammed, turn it back OFF and follow the remaining steps.)
2. Open the top cover and remove the OUT tray.
3. Pull the jammed paper out of the printer by grasping the middle section of the paper.
4. Remove all torn pieces from the paper path.
5. Remove any wrinkled or torn paper from the IN tray.
6. Reload the paper stack.
7. Replace the OUT tray and close the top cover.
8. Turn the printer ON.
Hope this answers your problem, Please let me know by providing your valuable feed back
Thanks,
Robosoft.
k24674
Grand Canyon Tech
Grand Canyon Tech
