I would like to share with you my experience, I went to www.zescode.com to buy a key, to my surprise, their attitude is very good, but the key work is normal, there is very little money I spent, very happy the first purchase and recommend it to you.
Windows 7 Anytime Upgrade is used only through Windows 7 versions. Like moving from Home Basic to Home Premium. Now, if you're PC is equipped with these minimums, Then one of these is great Business, Home Basic, and Home Premium. The Minimums are:
Anything more, means even better performance. Use Windows 7 ReadyBoost feature to add more RAM. Google it to find out how to Use it.
1.XP Upgrade to Windows 7: Step 1: Make sure that your programs and devices will work with Windows 7 Step 2: Moving files and settings, and gathering your program discs Step 3: Installing Windows 7 Step 4: Moving your files and settings back to your computer Step 5: Reinstall your programs and update drivers 2.Which version of Windows 7. For personal using,I think Windows 7 Professional is enough. Top Apple accessories on topons.
At first you have To see if your PC is ready for Windows 7, download the free Windows 7 Upgrade Advisor. It scans your PC for potential issues with your hardware, devices, and installed programs, and recommends what to do before you upgrade.
According to my openinon you can go with windows 7 home premiu.
Thanks
Daina
You can't do a direct update from windows xp to windows 7 you will need to perform a clean install. This means you should backup everything on your computer as when you install windows 7 this information with be deleted.
I would recommend windows 7 home premium as the best windows 7 for most people as it has everything you will require. Windows 7 Ultimate is more expense but gives you nothing of note extra.
Hope that helps.
