Brissel Healthy Home Hepa Vacuum:
On/Off Switch works sporadically. Took handle apart and the switch worked for a while. I am wondering if I need to replace the switch?
Also the Brush Switch is having similar problems.
- The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
first make sure the handle is tight you should remove it and put it back on. If that dosen't work you need take it to a bissell service center it IS under warranty
We had the same problem. Open the handle by undoing the screws and then pull one side off. Depress the button a few times and see if it catches. It worked for us and now it is just like it should be again. Good luck!
The most common problem is the handle isn't screwed in tight enough when the machine was assembled. Try tightening it down all the was and the electrical connections will then seat properly.
Easy Way 1) Go to Bissell.com and order the replacement handle for about $25 bucks. Follow installation instructions and viola! You're up and running again.
More Complicated (you're on your own) 2) I'm no expect by any measure. I just tinkered around and here is what I got.
Remove the handle (If you remember when you purchased the vacuum, you had to install the upper handle by connecting it midway and tightening it with a Philips screw).
I shouldn't have to say disconnect the power, but yeah, that's probably a good idea too.
Remove all screws in the handle. Keep note of which screws came from what area, mine were different sizes.
Split the casing open and remove the red plastic cover. You will find a small switch underneath
I just fiddled around with the small switch until it worked again; you can also go online and buy a new switch Click here for the switch only
Once you have the switch working, or purchased and installed a new one, put the handle back together and install again to the vacuum. You may want to test the switch before completely installing the handle. You can do this by connecting it without tightening the Philips screw in the middle.
Hope that helps a little. I know my wife was disappointed until I got ours up and running again.
The top handle connects to the lower half of the handle with one phiilips head screw. The screw is halfway between the cord holder on the back. The screw had come loose and the handle has slid back away making it not make contact to send the power down to the motor.
Hope this helps someone else!
