During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
