I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Timer will not turn off at indoor unit green light continues to flash although remote shows it off tried turning outdoor unit off for over 15 minutes but this makes no difference
There is a reset button on the right side of the wall unit i had trouble after cleaning the filter the book does not tell you anything about this but you have to push the reset after cleaning the air filters, not it works great,
Turning the power to the unit off for 20 seconds - to several hours, and then turning the power back on, has no effect. The error condition still exists. Also, there is no reset button on my unit. Thanks.
