Question about Toshiba 37AV502U 37 in. LCD HDTV
My toshiba 37av502u tv randomly shuts off and on. Sometimes the tv stays on all day, other times, it is constantly shutting off and on?
6ya staff
SOURCE:
Anonymous
SOURCE: toshiba md20p1c tv power won't stay on
The problem is Q401. Change it. It is a 2SC1624 but a 2SC1018 will also work. This solution will work for other Toshiba P combo units.
Posted on Mar 14, 2008
Anonymous
SOURCE: Viore 52' TV randomly shuts off. front lights blink then stop.
I am having the same problem with my PRT50V24D shutting off and blinking lights. After going to viore.com and calling the number listed, I got recording to call another number. When got rep on line I was told it is made by Samsung, Called their tech support and was told that sounds like power problem or bulb getting ready to go. Also if outside of warranty will have to call repair man to see what's wrong. I will have a repair man out next week and will post his results here. Most likely it's the same issue. This is the tech support number for Samsung 1-888-697-2247. Good Luck man. Matt
Posted on Dec 12, 2008
Anonymous
  • 6 Answers
SOURCE: Toshiba A205-S4607 Laptop
This may be a problem if your laptop has problems with heat. Being in a cool room with a lot of air-flow should solve this.
Although your laptop may have 'brain-damage' as such. In the respect that if you've dropped the laptop before or it has taken hits etc it may randomly turn it self on, or refuse to boot. If this is the case, there's no real way to deal with it.
Posted on Feb 21, 2009
Anonymous
  • 10 Answers
SOURCE: Random Shutdown
Toshiba's are notorious dust collectors, try blowing back through the air vents and some clever use of the vacuum cleaner on the intakes can bring it back to life. also check the RAM for dust and dirt on the pins and clean as required. USE ANTI-STATIC Precautions!
Amandeep Singh
  • 133 Answers
SOURCE: Shuts off Randomly
I'm sure about this one. Your Charger is faulty, buy a new one, it happened to mine as well, buying new charger solved it.
Posted on Mar 24, 2009
Toshiba 37 inch flat screen 37AV502U keep turning itself on then off randomly. Any ideas what it could be?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 20, 2016 | Toshiba Televison & Video
Tv shuts off and turns on by itself
The fault is with its main board, horizontal output section circuit. This is not a user repariable fault.
Jul 23, 2013 | Toshiba 36A40 36" TV
Westinghouse 32" TV randomly shuts off
It is a good possibility that you have 1 of your inverter transformers going bad. I wouldn't wait to have it looked at. It can cause more damage if the bad one let's go all together.
Oct 01, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
42 inch Samsung DLP TV shuts off by itself. I can turn it back on and sometimes it stays on and other times shuts off within seconds. Some days it stays on all day without a problem. Other days it shuts...
I bypassed the safety switch (it was bad) and vacuumed and blew out all of the dust. So far with this set, 3 years old, I have replaced the bulb twice,it exploded both times, and the color wheel which also exploded! We love the picture but the next time it goes out, it goes out to the trash and I will purchase a top of the line LED/LCD set. No moving parts!!! Samsung designed and manufactured a whole bunch of lemon sets and will not admit it. I have found several hundred complaints about their DLP sets and only a few on other brands.
Jul 31, 2009 | Samsung DLP HL-P5663W 56" TV
Shuts off Randomly
Mar 23, 2009 | Toshiba Satellite M45-S331 Notebook
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Toshiba 37AV502U 37 in. LCD HDTV Logo
237 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
