Question about Sony KDF-E55A20 55 in. LCD Television
Color Hue tends toward green
I've lost the color balance on my Sony KDF-55XS95 television. Even when I try to adjust the hue, I cannot get the color set properly - it either leans toward green (mostly), or red. I seem to have lost the ability to display blue.
  • 1 more comment
  • Anonymous Sep 16, 2008
    I have exactly the same issue on my 60" Sony WEGA.
  • dianeblan Oct 24, 2008
    Have a Sony KLV-S19A10. It's a 19 in. LCD. Just turned the tv on and saw these strange colors: Screen colors are green and violet only. No reds or blues. Tried adjusting the HUE but nothing changes.
  • Blueless Oct 27, 2008
    Blue works on DVD playback but not on regular TV Digital broadcast stations or programs. Hue adjustment does not resolve.
  • 320 Answers
Sounds like a bad optical block
Posted on Oct 18, 2008
6ya staff
SOURCE:
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Kp57hw40 is a greenish color
If green appears to bleed out of objects then it's probably the saturation level is to high. If that doesn't work you can try changing the Hue setting more towards red and away from green.
If neither works and you don't have a warranty I would call your a local TV repair company.
Oct 22, 2012 | Sony KP-57HW40 57" Rear Projection...
Green Hue on VGA Input on Sony KDF-E50A10
There is some color format mismatch. Look for settings and try to correct it. You may go through the operation manuals of both step by step. Also check whether the frequency of the device is same like both are of 50Hz or 60Hz.
Aug 02, 2012 | Sony KDF-E42A10 42 in. LCD Television
Sony kp-57wv700 cannot adjust color or hue
if you have a big sub right against it it needs to be moved away as the magnets can affect the big screen picture.
Mar 30, 2012 | Sony KP-57WS500 57" Rear Projection...
Sony Wega model kv-32fs120. Color is all reds and blues, no greens or yellows. We have tried adjusting the hue as per the owner's manual and also the re-set but nothing changes.
The color of the television are compose of three color RED,GREEN and BLUE.So the lost color is the green.The problem is in the color section of the CRT board in the chroma section and in the CRT socket board.Maybe theres a loose connection in the PCB like the cathode output transistor.
Sep 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KDF42A10 COLOR OFF
describe the yellow or green hue, is it eaven all over the screen or does it look like it is more noticeable on some portions of the screen. could be that you might need the light engine repair.
Jan 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
Dec 17, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Color is weird.
Component Video Jack was loose.
Dec 14, 2008 | Sony KP-48V45 48" Rear Projection...
NO Blue Colors on any station/program
If you are using component video cablesm make sure the blue is connected from tv to source.
Oct 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF-E55A20 55 in. LCD Television Logo
297 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
