Please could someone help with error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
You have a high voltage problem turn off copier and unplug it four a few minuts then repower, good luck
SOURCE: canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
i have IR 105 and IR72 missions. those two have sma problem R069. some time in not print totla page
canon ir 105 error code e000065000
FONCTION COPY BLOQUER
