Question about Casio 76 Key Smartmedia Keyboard
Hello, I have a CTK 601 keyboard and some key do not sound, I turn it off and on again, sometimes it works sometimes it does not. This is a set of 7 keys on the right part of it. pls advice
  • Casio Master
  • 5,603 Answers
Key contacts are dirty. The contacts are conductive rubber pills that get pressed against circuit traces on a board undder the keys. Clean the rubber pills AND the circuit traces with ONLY 99% isoprophyl alcohol and Q Tips. Be careful of the cables when opening the unit. There is also a slight chance that a cable has come partway loose internally. If you are uncomfortable with opening the unit and keeping track of all the screws, better take it to a repair shop.
Posted on Nov 29, 2010
Anonymous
SOURCE:
Ctk 5000 driver
I prefer, only in CASIO authorized service
Jun 29, 2013 | Casio Ctk-5000 Electronic Keyboard Piano...
Casio ctk-501 the power input cracked on the curcit board i did a bypass wiring over the crack and it got power works again but only till i start playing a bunch of keys then the sound gets stuck and the...
When wiring around circuit board cracks, one must use adequate sized wires and keep the leads short. Also you MAY have a microscopic crack in yet another conductor that flexes when you play the keyboard and freezes it. Use a high intensity LED light from the topside to "candle" the board and look for cracks. Look for cracking of the board material that may have tiny cracks in the circuit traces.
Nov 17, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
I have connected my casio to pc but pc songs and piano sound is not hearing in pc how it will work if any driver will use tell me about that i have casio ctk-2100 electronic keyboard
ASSUMING you have a MIDI interface connection, (not audio) then you need to set the PC to use a general MIDI sound and turn on the synth in the PC.
Go to control panel and open the sound icon. Select the device to use for MIDI playback in the appropriate section.
Sep 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
No Sound on my CTK 4000
See if you can hear any sounds via the headphones as a test.
Apr 20, 2010 | Music
Not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
Sep 03, 2009 | Casio CTK810 61 Key Keyboard
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Aug 17, 2009 | Casio 76 Key Smartmedia Keyboard
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
How to do a master reset a casio ctk 496
According to the manual for the 496, "All keyboard settings are returned to their initial defaults whenever keyboard power is turned back on after being turned off by operation of the Power/Mode switch or Auto Power Off.
Nov 26, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Casio 76 Key Smartmedia Keyboard Logo
170 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Norman  J Weimar Jr
Norman J Weimar Jr
Ekse
Are you a Casio Music Expert? Answer questions, earn points and help others
