Can you confirm that you get no sound and picture? Apparently, these units, along with Panasonic & Hitachi units which are similar in design and use the ALiS panel from Hitachi/Fujitsu have a weakness in power supply. If yours has this problem, you should at least get sound.
My Spheros started acting up (no picture) after a move as well. If yours has the same problem as mine, you could opt to replace the power supply by a Loewe rep and pay $1500. I just use a hair dryer to get the picture going. Let me know if you need the details.
Good luck.
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Were u able to fix the proble ? If not I'm lookingh for the Master Cable for this unit. Let me know if your willing to sell it; Chris [email protected]
