LG 42PC3D 42 in. Plasma Television Logo
Posted on Nov 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Tv has sound but no image. I have researched about this problem on your site and i need a Y-sustain board. Where can i buy one? Product code: 42PC3D-UD.A Serial #: 608RMZL066133 Thank you for your help.
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Nov 29, 2010
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783292
Points
6681
Check this link to find the Y sustainer board for your plasma.
I would suggest that before buying it, check the part number of the board from your TV.
Tv repair.for plasma tv
No screen boards found. Do you mean any of these?
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it might be time to start testing different boards to see if they are functioning properly.
Main Board
The main board is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. Main boards might also be referred to as a motherboard, main module, or an A/V board.
Power Supply Board
Another large and important board inside a television is the power supply board.. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
Timing Control Board / Logic Board
The timing control board, known as the T - CON board,, is typically only found on LCD and LED TVs. Plasma TVS, on the other hand, use a logic board.. The functions of the logic and T-CON board are similar, as each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixelation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
X-Sustain and Y-Sustain Boards
Also known as the X-SUS and the Y-SUS, the x-sustain and y-sustain boards only appear in plasma screen TVs. The x - sustain board might also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The x-sustain board activates all the display lines at once, while the y - sustain boardaddresses all the individual lines of display. When one board breaks down, it probably will not affect the functionality of the other. However, it might be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short life span anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
B uffer boards are also only found in plasma screen TVs. Connected to the y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
TV Boards Buying Guide
How to repair tv blackout
Sustain board fault. Contact any service technician to troubleshoot. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Hisense pdh4239eu lost image
Y-Sustain driver board got fault. Check it. If you wish to get some details, check the site linked here. Pull up older posts.
1helpful
2answers
My 42" LG plasma TV has sound but no image. Help!
Your posting does not say what TV are you talking about, but instead references an LG sustain board (EBR50267901), which is odd.
Where did you get that number from and why did you post it instead of the TV model?
If EBR50267901 is indeed the board you need serviced or replaced, here is a link for you:
http://www.coppelltvrepair.com/p/558/buy-lg-ysus-ebr50267901-sustain-send-your-old-dud-back-to-receive-credit
Hope this helps!
2helpful
I headrd a POP sound and my TV would not turn on and red light would blink 7 times. Will
hi,
if this is a plasma TV you may have an issue with something that is called a X-sustain or a y-sustain board. these are the board that control the image on the screen, its referred to as the "POP of death" i would suggest opening the TV inspecting the boards (they are usually the board on top with aluminum heat sinks) and looking for busted or burnt capacitors!
1helpful
2answers
Sound is on but screen is black, remote changes channels but no picture
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
The screen on my Hitachi 42EDT41 went blank. I still have sound, but no image. POssible problems/solutions? Thank you!
This is a common plasma tv problem. I changed the Y-sustain board and the Z-sustain board and that fixed my "sound, but no picture" problem. You can find both boards on ebay; the Y-sus board is around $100 and the Z-sus is around $50. Hope this helps.
LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
2answers
Lg 50px2dc no image just sound
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
