Check
the brushes in the motor, replace if less than 3 or 4 mm long. If prob still
persists, then the control board is probably faulty.
However
If your washer spins but does not pump the water out, the drain
line is probably clogged. In many washers a small sock or other piece of
clothing can get between the clothes tub and the outer tub that holds the water.
If the clothing gets between the tubs, it may then get into the drain hose that
is attached to the pump or even into the pump itself. It it's in the pump, you
need to remove the hoses from the pump and pull the item out.
To remove the item from the outer tub port, open the washer's
main access panel and remove the large diameter rubber hose that connects the
pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and
remove the stuck item through the port.
Check your washer for a frozen pulley. Remove the pump from the
washer and try to rotate the pulley manually. If it doesn't turn freely, it's
frozen, replace it.
If the water that pumps out of the machine goes back after the
spin cycle, your washer is siphoning the water from a laundry tub that has a
slow drain back into the washer. The usual remedy for this is to improve the
draining of the laundry tub.
Also check for these problems:
If the drain hose reaches more than 4 inches into the laundry
tub, cut the excess.
If your drain hose is lower than the washer's cabinet, install an
air gap/siphon break assembly.
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
? 11:33
https://www.youtube.com/watch?v=TB_W6sPdzkM
Jul 10, 2012 - Uploaded by Bill Newberry
Kenmore / Whirlpool Washer Not Spinning 1. Bill Newberry ... Washer will not spin the clothes dry ... Now ..
is there any kind of heat going into the dryer if there is then 1 off your thermostats have gone if not them 1/2 off the thermostats have gone faulty these are situated on or near the heater element they are small round and have 2 wires coming from them change these and it will work properly love
The drain pump is jammed or clogged up. Remove the filter cover and check for bobby pins, coins or bra wires. If clean, remove drum to pump hose from the pump and check for any foreign matter. Try to turn the pump impeller by hand. It should turn freely. If pump is not free, replace it.
